fangbaby4513
1) Visual finish foil is finish foil printed with embossed lacquer top coating, the visual effect is synchronous to the design pattern and shows and a vivid visual aesthetics feeling. 5 feet size width is specially designed for 5 feet wide boards used in North and South American regions. This visual finish foil is widely use as lamination and wrapping material for cabinets, door frame, profile, shelf, wall-panels, etc in furniture, decorating industry.
2) All kinds of wood grain, stone, metal, linen, artistic design and solid colour can be combined with the visual surface effect.
3) Certified by ISO9001, FSC, SGS, etc.
4) Base paper: 45-80gram/sqm. environment friendly based paper from Japan and Germany.
5) eco-friendly ink and coating.
6) Standard width: 1575mm(5feet).
7) Samples are available.
8) Packing: 1000-3500m/roll, 2-4rolls/pallet, standard export seaworthy packing.
9) Both FCL and LCL are acceptable.
10) High quality comprehensive and service.
Visual Finish Foil
website:http://www.hoyo-decor.com/finish-foil/visual-finish-foil/
Visual Finish Foil
