Dana Wardell
Complete! Ready to run, just freshened and completely gone thru.
451 cubic inch, TFX cast aluminum block. Blown Brad 5, alcohol engine
BRAD 5 billet cylinder heads with new springs, valves, fuel rocker assembly
BAE black powder coated valve covers with burn down tubes/hoses
Callies crankshaft
New Bullet cam and valve train
GRP Rods
Arias Pistons
Kobelco 14-71 high helix, front discharge supercharger
Four hole carbon fiber hat, K-valve, restraint plate with DJ straps, new black fuel lines.
Autometer boost and oil pressure guages
Front idler plate and upper-lower pulleys and belt
RCD Belt Guard - starter cage - starter dog
Fuel Filter
New dry sump oil pump and lines
Olson aluminum dry sump pan and lines
MSD 44 mag, boxes, coil and wiring
Enderle 1200 19.8 gallon pump with pump loop, lines and check valves, fresh just checked by Waterman
DJ Blower Restraints and plate
$24,000 ready to run, add oil and fuel be ready to run, or can be purchased as a long block, manifold to pan less the fuel, blower and ignition systems $18,000.
Contact: Dana Wardell, [email protected] or phone 916-849-3551
Callies crankshaft
GRP Rods
Arias Pistons
Fuel Filter
