Dana Wardell
BE READY FOR UPCOMING SEASON! fresh 526 cu. Inch, 10.7 deck. billet MBR engine, FRESH BACK FROM MBR, manifold to pan, 4.125 stroke, 4.500 bore, 11.6 to 1 compression, Newton billet block, billet MBR heads, cast magnesium intake manifold, GRP rods, Arias pistons, Olson oil pan, cast magnesium timing cover, full valve train with black powder coated MBR valve covers, Crane cam, Morel 1 inch lifters, 2.600 intake valves, 1.950 exhaust valves, RCD crank hub with crank trigger degree wheel, crank has just been magged and polished with .010 under mains and standard rods, no oil pumps or pulleys, both have fresh or new main caps, with fresh line hone, fresh honed or new sleeves, new rings, fresh valve jobs with 2.60 titanium intakes and stainless exhaust valves, fresh valve springs, in great shape. race ready and should be competitive has been in the 5.50's in an Alcohol Funny Car with a best of 5.52 259. comes with non roller steel rocker assembly $20,000 plus the ride. Compare to new one from MBR at around $52k.
Contact Dana Wardell (916)849-3551 or [email protected]
