526 CI Engine (just idle time since new) - $25,000
CN Billet Block 1041Y - 4.840" Bore space + .400 high cam / cross bolted cap - Dry block
Sonny Bryant Billet Crank 4.125 stroke
Total Seal Rings
Venolia Rods
CP Pistons 4.500" bore
Dan Olsen oil pan - Dry sump
Crane pro series lifters
Pro-filer 12 degree cylinder heads
RCD gear drive
Victory Titanium valves
T&D Rockers
Manton push rods
SCE head gaskets
Indy intake with burst banel
Have Taylor engine diaper (out of date) - $ 250
Lenco CS-1 4 Speed with reverse $ 4,500
Green clutch disc / Steel floaters
32 x 35 Int. shafts / 32 spline output / 1.375" 10 Input
Large Sprag
1.46 - 1.41 - 1.38
Configured as a three speed with air pods - can be configured with front mount shifter handles
Crower 10.5" dual disk pedal clutch Chevy - $ 1,750
Browell Bellhousing
BBL-6.3AR heavy wall, Billet fork (8 1/8") for lenco - $1,000
147-1 Kobelco hi-helix supercharger (Long Snout) - $ 4,750
JBR Carbon Injector hat - $ 3000
Taylor 14.2 blower restraint (out of date) - $ 500
MSD 10 #7505 ignition with coil - $ 600
2 - 8mm Blower Belts - 1600-84PS - Gates/RCD
Have other PM/alcohol items selling complete PM operation.
[email protected]
Total Seal Rings
Venolia Rods
RCD gear drive
T&D Rockers
Manton push rods
SCE head gaskets
Large Sprag
1.46 - 1.41 - 1.38
Browell Bellhousing
[email protected]
