CPT has in house casting and forging capablity to meet customers special and unique demand. MaterialCast iron, ductile iron, steel Mold TypeWood pattern, aluminium mold, lost foam, etc. AdvantageStrong design capability Produce in-house 23 years manufacturer ISO9001:2008 certified Main Product-3D Printing Prototype -CNC Milling Machining Plastic and Metal Parts -Plastic Mould/Tooling/ Diecasting -Injection Molding Product, Injection Foaming Mold, Gas Assisted Injection Molding (part for Auto, Medcial, Aerospace, Houseware鈥? CNC machining parts material metalAluminum(6061,6063,7075...), Stainless Steel(301,302,303,304...), Brass, Copper, metal sheet CNC machining parts material plasticABS, PC, ABS+PC, PMMA, Acrylic, POM, Delrin, PTFE, TPU, TPE, PU Tolerance+/-0.05mm Surface TreatmentPolishing, Brushing, Painting, Anodizing, Silk Screening, Laser Cutting, Texture, Sanblasting Data for quote2D, 3D, samples Quanlity SystemISO 9001: 2019 We PromiseAll customer-centric, never for short-term profit, and sell long-term benefits Material:Cast/Ductile iron, steel, bronze and others Types:Replacement parts for hydraulic piston pump Function:Completely interchangeable with original pump Parts nameCylinder block, piston, retainer plate, ball guide, valve plate, drive shaft, swash plate and more Processing technicCutting, lathe, machining center, heat treatment, grind, honing, burring and so onOEM Pump Parts website:http://www.metalpart.net/pump-parts/ |
