fangbaby4513
IND-P5836D
Applications
IEEE 802.11a/n WLAN System
Smart Home Systems Signal Extender
Wireless Cameras Signal Extender
Drone Signal Extender
Features
100X the power, improving the link quality and coverage of certified WLAN devices.
3.0dB ultra-low noise.
Wide 6V to 16V operating input range.
Working with certified IEEE 802.11a/n Wireless LAN devices.
Simply plug and play, no software is required.
Parameters
NumberItemsSpecifications
1Frequency Range5725-5850MHz
2Operating Voltage6-16V
3Receiving Gain15dB±1
4Transmission Gain20dB±1
5Max Output Power (P1dB)36dBm (4W)
6Input Trigger PowerMin: 3dBm; Max: 17dBm
7EVM3% @27dBm 802.11a 54Mbps OFDM 64QAM BW 20MHz
8Noise Figure<3.0dB
9Current Supply420mA @Pout 27dBm 12V
10TX/RX Switch Time Delay<1 us
11LED IndicatorTransmitter: Green; Receiver: red
12Operating Temperature-30℃~+70℃
13Storage Temperature-40℃~+150℃
14Operating HumidityUp to 95% rel. humidity
15RF ConnectorInput: SMA-K; Output: RP-SMA
16Power Socket2.5*0.7mm DC ( default ) or 10cm red/black wire
17Shell Size76.3*34.4*13.2(mm)
18Shell MaterialAluminum
19Net Weight0.06Kg
Dimensions
Attentions
1. 12V /1A power supply.
2. Heat dissipation is recommended, such as adding heat sink or radiator fan.
3. Antenna should be screwed first, then plug the power adapter, finally connect the device.
4. The output could reach 36dBm, when input power is 16dBm or 17dBm (default gain is 20dB).Bi-directional Power Amplifier manufacturers
website:http://www.ind-booster.com/bi-directional-power-amplifier-bda/
Applications
Features
Parameters
8Noise Figure<3.0dB
19Net Weight0.06Kg
Dimensions
Attentions
