526 MBR - COMPLETE Billet Block - Billet Heads - Manifolds, Plus Parts
Dana Wardell
Have a fresh 526 MBR, just back from Miner for final machine work, assembled in our shop, complete manifold to pan, 4.125 stroke, 4.500 bore, 11.6 to 1 compression, Newton billet block, billet MBR heads, cast magnesium intake manifold RCD front fuel pump extension, GRP rods, Arias pistons, Olson oil pan, cast magnesium timing cover, full valve train with black powder coated MBR valve covers, Crane cam, Morel 1 inch lifters, 2.600 intake valves, 1.950 exhaust valves, RCD crank hub with crank trigger degree wheels, crank has just been magged and polished with .010 under mains and standard rods, no oil pump or pulleys, has new main caps, with fresh line hones, fresh honed or new sleeves, new rings, fresh valve jobs with 2.60 titanium intakes and 1.95 stainless exhaust valves, fresh valve springs, everyting is in great shape. engine is race ready and should be competitive and has been in the 5.50's in an Alcohol Funny Car with a best of 5.52 259. MBR roller rocker assembly, RCD front crank support, NEW cera coat on magnesium valve covers-black.. $24,000 plus the ride. Compare to new one from MBR at around $52k.
572 8.3 ltr. Arias blown alcohol engine. complete ready to run solid cast 11.2 deck block, water cylinder head engines. Complete from injector to pan. Enderle upright injectors, Littlefield 14-71 superchargers, Arias 4.50 pistons, Brooks/grp rods, billet 4.50 crankshaft, roller cam and lifters, Manton push rods. Endelle 1200 fuel pump, external Peterson oil pump, wet sump Olson steel pan, front magnesium cover and mag drives mag drive with Mallory V mag and wires. $15,000 need freshening, " $500 credit on SHIPPING IN LOWER US."
2 sets of blue rocker assemblies, non roller, complete in immaculate condition. $800.00 set, plus the ride.
Gold, later style rocker stands, no shafts or rockers, just the stands, complete set of ten to accmodate one pair of heads or use as spares, $300.00 shipped to you.
Stack of misc thickness copper head gaskets, 4:375 , $50.00 per pair, plus the ride
Billet MBR pair of single plug heads, assembled with 2.40 titanium valves, springs and retainers, valves, updated intake MBR mods, complete, nice condition $2,000.00 set plus the ride. Pictures available.
Billet MBR (2) pair of late model single plug heads, assembled with fresh/new titanium valves, springs and retainers, very nice condition, $4,000 set. one complete fresh spare for these heads $2,500.
Fontana late model magnesium dual plug valve covers. Powder coated black valve covers $600 pair.
MBR - Dan Olson aluminum oil pans, 3 - $400 ea. plus the ride
If you don't see what you need here, let me know, have access to lots of newer MBR 8.3 ltr. and older 8.3 ltr. Arias parts.
Contact Dana Wardell, Phoenix Motorsports LLC, [email protected] or (916) 849-3551 PST.
